plot residual for parametric analysis
Hi at all, this is my first time in this forum.
I carried out a parametric analysis in Fluent. The parameter is the first layer for the infation (in mesh generator). After the calcolation how I can see the residual plot for each simulation in order to view how the model has reached convergence? thanks |
Hi teo,
first, let me welcome you here. I'm not sure what you exactly want to achive, but you could print the residuals into jpegs an compare them in the end. If you want to have them all in one plot you should write them into a file. I think you find the option in the plot residuals menu. Greetz Jim |
Hi Jim. Thanks for your answer!
For example, if I have a simple cylindrical pipe and I do a parametric analysis varying the diameter (5 mm and 10 mm), when the simulation is ended how can I see the residual plot for the two different simulations? teo |
Maybe I had forgotten to export the files...
