Ideal Gas properties- Axial turbine-need help in linking temperature and pressure
Old   June 15, 2013, 04:50
Default Ideal Gas properties- Axial turbine-need help in linking temperature and pressure
Gowrav Shenoy
Gowrav is on a distinguished road
Dear Forum Members,
As a part of my masters project, i am simulating CFD flow simulation of microturine. I am using slidingmesh-unsteady/ MRF-steady models with realizable k-epsilon. Press in -Press out are my BCs with tot-tot Pr.Ratio 2.. I am able to get pressure plots over blades after convergence (material -air with polynomial prop wrt temp over range of 800k-1300k), bt temperature and its related properties are not varying with the flow. in other words compressiblity is nt gt linked..
So i changed material to gas with ideal gas density and kinetic theory related viscosity and specific heat.(A benchmark case of nozzle worked correctly with this change. ie. press change and temp change observed). Now am getting divergence error with amg solver. Problem still nt solved after changing relaxation factors..
Can anyone pls tell where its gone wrong and how to correct..
Thanks in advance
Gowrav
Gowrav is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
