DES Length Scale,grid spacing,delta max
Old   January 27, 2014, 08:11
Default DES Length Scale,grid spacing,delta max
Ali.E
behest is on a distinguished road
Hello all,
I want to compute delta x (distance between two cell points) in a 3D simulation. Actually, I want to caclucate DES Length Scale and maximum grid spacing is a important parameter to calculate. Actually, 3 grid spacing is needet to calculate in 3D problem and the maximum of them is used in DES Length Scale calculation. My problem is how can I find the grid spacing for each cells. Please help me
behest is offline   Reply With Quote
Old   February 5, 2014, 15:29
Unhappy
Ali.E
I think that the best way is writting a udf which computes the length scale.
the length scal equation is:
L_s=sqrt(k)/(Bs*delta_max*C_des*w)
Bs=0.09 , C_des=0.61
k=turbulent kinitic energy
w=specific dissipation rate
delta_max=max(delta_x,delta_y,delta_z)
may I ask you which macros should be used?
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
Force can not converge colopolo CFX 13 October 4, 2011 23:03
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
