June 15, 2013, 16:56 |
Solid particles in a flow
Rep Power: 13 |
I'm trying to simulate individually defined solid particles (as shows the attached figure) in a fluid of the same or almost the same density. I have set the VOF multiphase model and define the particles as fluid with very very high viscosity and the fluid is a Newtonian fluid. Both materials have same density. The problem is when I run the simulation particles are united into a unique volume. I don't want to happen this, in other words particles must not mix together. I try it to do it as solid material but the interface between the faces is defined as wall and the particles don't move with the fluid. If anyone can help me, I would be very grateful. If you have any other idea or way to do the same or something similar it will be welcome. Last edited by asier; June 15, 2013 at 19:28. |
multiphase, multiphase unsteady, particle tracking |
Display Modes | |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
Modeling solid particles within fluid flow | steelydan | ANSYS | 1 | July 22, 2011 03:01 |
solid particles | sacha | CFX | 5 | November 10, 2003 12:29 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
