June 15, 2013, 18:31 |
Doubt about Rotatory Analysis Setup
Arthur Loginow
Hello, greetings to all, imagine that the following geometry is a volume of fluid, and it has 2 inner cylinders rotating in opposite directions, inside of it, my question is, how would you setup this particular model? I am asking this because so far, the only thing that I did was to specify that both cylinders are walls that are rotating, that is all, but I am not so sure that that is right. Any help will be more than appreciated.
Thanks Last edited by Maralady; June 15, 2013 at 20:46. |
June 15, 2013, 19:54 |
Arthur Loginow
My doubt here, is that I have 2 rotating axis, but just 1 volume, therefore I should not use MRF, but I should not use SRF either, I have just 1 cell zone, with 2 rotating axis, that makes it pretty confusing.
Arthur Loginow
I tried some tests with the set up of the walls, and it gave me some logic results, but again, I am not sure if that procedure is correct.
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
rotating and vibration setup | liuzexiang | CFX | 2 | January 30, 2013 16:41 |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
Best choice for my setup ? Sliding mesh or single rotating ref frame ? | Rockda | FLUENT | 0 | August 23, 2011 05:05 |
Please help Single rotating frame Setup | jaswi | OpenFOAM Running, Solving & CFD | 0 | June 8, 2007 08:24 |
