Rotating Setup Doubt
Old   June 15, 2013, 18:31
Default Doubt about Rotatory Analysis Setup
Arthur Loginow
Maralady is on a distinguished road
Hello, greetings to all, imagine that the following geometry is a volume of fluid, and it has 2 inner cylinders rotating in opposite directions, inside of it, my question is, how would you setup this particular model? I am asking this because so far, the only thing that I did was to specify that both cylinders are walls that are rotating, that is all, but I am not so sure that that is right. Any help will be more than appreciated.
Thanks
Maralady is offline   Reply With Quote
Old   June 15, 2013, 19:54
Arthur Loginow
My doubt here, is that I have 2 rotating axis, but just 1 volume, therefore I should not use MRF, but I should not use SRF either, I have just 1 cell zone, with 2 rotating axis, that makes it pretty confusing.
Arthur Loginow
I tried some tests with the set up of the walls, and it gave me some logic results, but again, I am not sure if that procedure is correct.
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
rotating and vibration setup liuzexiang CFX 2 January 30, 2013 16:41
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
Best choice for my setup ? Sliding mesh or single rotating ref frame ? Rockda FLUENT 0 August 23, 2011 05:05
Please help Single rotating frame Setup jaswi OpenFOAM Running, Solving & CFD 0 June 8, 2007 08:24
