-   -   Conjugate heat transfer problem (http://www.cfd-online.com/Forums/fluent/119383-conjugate-heat-transfer-problem.html)
troyker June 16, 2013 11:44
1 Attachment(s)
Hi, every one.
I am new in fluent.
I found a tutorial about solving conjugate heat transfer problem using ANSYS FLUENT.
On step 4 of the tutorial , materials create, it worte "These materials are assumed to have the same density and heat capacity as that of aluminum, but different thermal conductivities."
My problem is why could it setup?
Bescause it is a steady state simulation?
If the simulation is transient, will the density and heat capacity have to setup the correct values?
Thanks.
aditya92in March 22, 2014 14:46
air has been clearly predefined as material in fluent itself, use those material properties for air
