standard wall function and mesh resolution
Old   June 20, 2013, 15:31
Default standard wall function and mesh resolution
Ian Gaetano Monda
igmonda is on a distinguished road
Hi All,
I have a question with regards to the boundary layer mesh requirements when using the K-eps turbulence model with standard wall function.
The user guide says that in order for it to be valid you need y+ values of 30-300. Also says you need a few of additional cells in the bl (does not state how many).
My question is if I mesh surfaces and then grow my volume mesh at a reasonable growth rate (say 10-15%) will I achieve the above assume my y+ is 30-300? Or maybe were my y+ is close to 30 I have additional cells in the boundary layer and where y+ is close to 300 I have only 1 cell in the boundary layer? Is there a way of interrogating number of cells in the boundary layer in Fluent? If you have only 1 cell in the boundary layer then what are the implications when using the standard wall function?
Cheers,
Ian
igmonda is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
