-   -   mixing tank (http://www.cfd-online.com/Forums/fluent/119690-mixing-tank.html)
wemendibe June 22, 2013 13:29
mixing tank
If I put 100 rpm rotational velocity to the impeller in the mixing tank it converge, but if I put 500 rpm it does not converge, do anyone knows why??
I put in viscous model k-epsilon RNG, because it is turbulent, I can say if anyone knows all the steps that I have.
Thank you
Mikel Mendibe
Far June 23, 2013 04:27
At off-design conditions you will have more separation and hence difficulty in converging steady state solution.
wemendibe June 23, 2013 05:19
So, do you mean that is normal to do not convege?
Far June 23, 2013 06:16
yes, if it is not a design condition. At off design conditions you may need to activate unsteady flow solver.
wemendibe June 23, 2013 06:32
Thank you. I have another question, I want that the wall of the tank heat the fuild that I have. I go to the wall and I put the temperature that I want, is it ok?
Thank you
Far June 23, 2013 06:39
yes. Also enable energy equation.
A CFD free user June 25, 2013 03:22
You should increase the impeller speed gradually untill to reach your desire speed. For instance, to do a simulation with 400 rpm, first start with 100, then increase it about 20 rpm and go ahead. once I had the same problem too. Try this it helps.
