June 24, 2013, 16:30 |
Geometry Help
Louisiana
Rep Power: 12 |
Hello All,
I am trying to design a simple 2D model. The simulation is to be a heated flat plate to observe buoyancy driven flow. So, the top of the domain is to be fluid with a solid (heated) surface underneath. The problem is that I am trying to model a micron scale asymmetric structured surface that is basically a repeated asymmetric triangle. So I need the fluid domain to match/mirror the solid surface. I can model the solid, but I cannot seem to get the fluid sketch to work. I am pretty new to FLUENT so please don't overlook a simple solution. I have also tried doing this in Solidworks. I modeled the fluid and solid domains as separate parts then mate them, but I cannot mate 2D drawings so I extruded them a small amount. When I try to mesh it, the computer freezes. Please help! |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS | kamran_kibria | ANSYS Meshing & Geometry | 0 | September 15, 2011 05:14 |
Reg difficulties in meshing the geometry...Urgent | arunraj | ANSYS Meshing & Geometry | 0 | August 26, 2011 23:25 |
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry | villier | OpenFOAM Meshing & Mesh Conversion | 17 | June 15, 2010 19:51 |
[GAMBIT] import terrain geometry | cfdworker | ANSYS Meshing & Geometry | 2 | May 24, 2009 21:40 |
