-   -   Heat Flux Doesn't Work (http://www.cfd-online.com/Forums/fluent/119825-heat-flux-doesnt-work.html)
ryzd June 25, 2013 18:58
Hi all,
I can't tell what I'm doing wrong. I'm trying to model 2D turbulent flow through a pipe. The lower wall of the pipe is held at a constant temperature and the upper wall has a heat flux of 7.795 W/m^2. When I run the simulation it appears there is no heat transfer through the upper wall.
I should be dumping A LOT of heat into the fluid, but the result of the simulation shows almost a constant temperature along the upper wall.
Please Help,
-Ryan
ryzd June 26, 2013 11:13
This doesn't seem like it should be a very difficult problem. Can't anyone help?
