February 12, 2011, 12:31 |
Diesel Unsteady Flamelet Error
Hi All,
I'm attempting to use Diesel Unsteady Flamelet for Diesel engine combustion case with CHEMKIN reaction mechanism imports. There is however an error message (shown below) when I attempt to initialise the case. Much appreciated if anyone can explain or help out. ================================================== == Error Object: #f Tox = 313 K, Tfu = 313 K, <X> = 0 /s, <p> = 101325 Pa Initializing unsteady flamelet Failed to calculate stochiometric mixture fraction: Assume fsto=0.5 Done. Generating PDF lookup table Type of the PDF Table: Nonadiabatic Table with Single Flamelet Model (Two Streams) Calculating table ..... Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f ================================================== |
June 26, 2013, 16:45 |
#2 | |
ALj89
Rep Power: 12 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
