June 30, 2013, 12:43 |
ANSYS Fluent Run
Sa.Baraty
Rep Power: 13 |
Hi All.
i want to run many mesh files.how i can adjust ansys fluent that automatically run all my case file subsequently? please help me. |
June 30, 2013, 21:02 |
Christopher Hershey
Rep Power: 14 |
A journal file would probably be the best bet. Do you have experience with them? They are essentially a set of instructions that are read in by Fluent and will actually set up the problem and run the case with only a few lines of text.
However, do you know if these cases you want to run are actually going to work? If you set up several cases to run one after the other then it might fail if there are errors that pop up. If you give me more information on what you are looking to do, then I can probably help you out. Are you starting from scratch or do you have case files already saved and ready to be started? |
GPU acceleration on ANSYS Fluent 14.5 | Daveo643 | FLUENT | 20 | April 28, 2018 13:50 |
Fluent v6.3.26 better than Ansys v12.1 | jemyungcha | FLUENT | 2 | August 24, 2012 23:10 |
Loading of Temperature datas from ansys to fluent! need help!! | tensun | FLUENT | 0 | November 6, 2010 00:35 |
Hardware for running ANSYS Fluent 12.1 | ngj_22 | Hardware | 2 | September 29, 2010 07:26 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 14:04 |
