Moving FSI
Old   July 2, 2013, 10:10
Default Moving FSI
Jiang
Jiang is on a distinguished road
Hey all.
I have a problem currently at assigning the dynamic mesh zones. I'm trying to study FSI in a pressure valve, on the valve disc. I get this zone called valve_disc-shadow. Normally if I'm studying FSI without a moving mesh, then i would leave it as it is. but if i have a moving mesh for the valve_disc
The valve disc would move, leaving behind the valve_disc-shadow, therefore the new mesh is not being generated.
Anyone know the correct way to do this?
if more infois needed, regarding the problem please ask.
Thank you
Jiang is offline   Reply With Quote
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
"wall normal velocity" on moving surfaces (FSI) andey CFX 6 February 24, 2010 02:37
Moving mesh problem with a FSI solver mathieu OpenFOAM Running, Solving & CFD 8 January 25, 2010 09:08
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
moving wall- FSI skd FLUENT 0 May 8, 2006 09:21
