July 4, 2013, 01:23 |
Run
Sa.Baraty
Rep Power: 13 |
Hi All.
i want to run many mesh files.how i can adjust ansys fluent that automatically run all my case file subsequently? please help me.
thanks |
July 4, 2013, 01:45 |
Suppose you have a case file named 'runa.cas', you can save the settings for this case with the text command
/file/write-settings "run.settings" Code:
/file/set-batch-options no yes no /file/read-case "runb.msh" /file/read-settings "run.settings" /solve/initialize/initialize-flow /solve/iterate 1000 /file/write-case-data "runb.gz" /file/read-case "runc.msh" /file/read-settings "run.settings" /solve/initialize/initialize-flow /solve/iterate 1000 /file/write-case-data "runc.gz" ... I assume that your FLUENT version is new enough to accept the Code:
/file/write-settings |
Parallel run in fluent for multiphase flow | apurv | FLUENT | 2 | August 3, 2011 19:44 |
Batch Run with Initial values file | krrishcfd | CFX | 1 | July 28, 2011 02:35 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
How to run and save tranisent case on Cray XD1 | Leon | FLUENT | 0 | October 3, 2006 21:59 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
