turbulent viscosity
Old   July 4, 2013, 01:21
Exclamation turbulent viscosity
Sa.Baraty
sara22 is on a distinguished road
Hi all.
i modeled pipe in fluent. boundary condition : inlet mass flow inlet.
out: pressure outlet, and constant heat flux at ambient of pipe.i use k and Epsilon turbulent model and my fluid is methane.when i run my problem this error appear :
"turbulent viscosity limited to viscosity ratio of 100000 at .... face"
please help.
thanks
thanks
sara22 is offline   Reply With Quote
Old   July 4, 2013, 04:50
Gimlas is on a distinguished road
In order to achieve a stable solution Fluents limits some parameters like turbulent viscosity if they exceed a given limit (which may be changed according to user needs) during the calculations. You shouldn't worry about that and let the solver perform more iterations. After some calculations (sometimes few hundreds of iterations, sometimes few thousands depending on mesh size and solver settings) this error should dissapear. In other case, you should revise your mesh and solver settings (especially boundary conditions).
Gimlas is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
