Home > Forums > FLUENT
Run
Old   July 4, 2013, 01:23
Exclamation Run
Sa.Baraty
sara22 is on a distinguished road
Hi All.
i want to run many mesh files.how i can adjust ansys fluent that automatically run all my case file subsequently?
please help me.
thanks
sara22 is offline   Reply With Quote
Old   July 4, 2013, 01:45
blackmask will become famous soon enough
Suppose you have a case file named 'runa.cas', you can save the settings for this case with the text command
/file/write-settings "run.settings"
Then you could write a journal file, which looks like
/file/set-batch-options no yes no
/file/read-case "runb.msh"
/file/read-settings "run.settings"
/solve/initialize/initialize-flow
/solve/iterate 1000
/file/write-case-data "runb.gz"
/file/read-case "runc.msh"
/solve/iterate 1000
/file/write-case-data "runc.gz"
Of course you could use an equivalent scheme script to do the loop.
I assume that your FLUENT version is new enough to accept the
text command.
blackmask is offline   Reply With Quote
Thread Tools
Trackbacks are On
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
Batch Run with Initial values file krrishcfd CFX 1 July 28, 2011 02:35
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
How to run and save tranisent case on Cray XD1 Leon FLUENT 0 October 3, 2006 21:59
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
