C_UDSI_G() use in DEFINE_ADJUST
Old   February 3, 2009, 04:34
Default C_UDSI_G() use in DEFINE_ADJUST
Gemini
Hi, I found a solution for the archived post below. Here an example for C_UDSI_G() use in DEFINE_ADJUST
real my_mag = 0.0;
thread_loop_c (t,domain)
if (NULL != THREAD_STORAGE(t,SV_UDS_I(uds_index)) &&
NULL != T_STORAGE_R_NV(t,SV_UDSI_G(uds_index)))
begin_c_loop (c,t)
my_mag = NV_MAG(C_UDSI_G(c,t,uds_index));
end_c_loop (c,t)
-----------ARCHIVED POST------------
When I use a C_UDSI_G in DEFINE_ADJUST, the access_violation error came out.
if I start iteration without hooking the adjust fuction,the iteration executed ,after some steps, I hooked the adjust function and initialized ,the iteration continues . I guess this is because the gradient of C_UDSI(C_UDSI_G ) isn't allocated yet ,but the codes do contain the if (! Data_Valid_P())return; sentence?
I check the id.h in the src file as: FLUENT_EXPORT boolean Data_Valid_P(void); The FLUENT_EXPORT usually provides a GUI operation interface.am i right?
can some one give me some suggestion that how to let Fluent iterate when hooked a adjust function which contains C_UDSI_G other then let it iterate some step without hooking this adjust function? and the reason for this? thanks in advance
Old   July 5, 2013, 00:12
Chuang Wei
danieldmgy is on a distinguished road
I have the same problem to solve a transient problem. I guess you are right that C_UDSI_G needs couple of timesteps to be allocated.
It turns out no more than 4 timesteps works for me. The reason for that is unknown and I cannot find explaination in UDF manual. But anyway, just don't use the serveral inital timesteps. This may work.
Originally Posted by Gemini
;156362
real my_mag = 0.0;
begin_c_loop (c,t)
end_c_loop (c,t)
danieldmgy is offline   Reply With Quote
C_UDSI_G(c,t,UU) returning NAN Travis FLUENT 1 February 17, 2009 05:51
Could I use DEFINE_ADJUST to set B.C ? pour FLUENT 0 May 22, 2008 13:07
C_UDSI_G() in DEFINE_ADJUST shuqin FLUENT 2 June 18, 2006 00:12
About DEFINE_ADJUST sagga FLUENT 1 February 3, 2006 09:49
DEFINE_ADJUST Tomm FLUENT 0 December 7, 2005 10:53
