Home > Forums > FLUENT
Startin calculation from specific previous iteration step
Old   July 4, 2013, 08:02
Default Startin calculation from specific previous iteration step
hekseli
heksel8i is on a distinguished road
Hey!
Is it possible to start a new iteration with new setup from a specific previous iteration step? I used to do that a lot with OF but now with Fluent I couldn't find a way to do it.
heksel8i is offline   Reply With Quote
Old   July 4, 2013, 11:07
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
Hi mate,
if you're using Fluent via workbench, just connect from "Solution" of problem which has been solved to "Solution" of problem which you wanna start from last one. See the pircture:
If you are using Fluent as standalone, and you just change the setup within one file, just start calculation without initializing; it will start from last run.
If you use Fluent as stanalone and files are different (meshes are different in two files), you need to interpolate (File->Interpolate) to write a data file from first problem and then interpolate to read data from file you just created.
ICEM, CFX and Fluent expert
sadjad.s is offline   Reply With Quote
Old   August 6, 2013, 13:28
navid
ndabir is on a distinguished road
I am having a similar problem. I am using coarse mesh for an unsteady simulation until a specific time. Then I interpolate results and initiate another case with same setup but finer mesh to continue my simulation. The problem is residuals don't converge good. I have decreased time step and also decreased under-relaxation factors but nothing changes. any suggestions please?
ndabir is offline   Reply With Quote
Old   August 6, 2013, 22:11
François Grégoire
macfly is on a distinguished road
I'm a little confused: do you interpolate and initialize? Because if you initialize you lose the interpolated data and restart at t=0.
macfly is offline   Reply With Quote
Old   August 7, 2013, 00:33
navid
no. I just interpolate but the residuals are not good.
Thread Tools
Trackbacks are On
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
Simulation of a single bubble with a VOF-method Suzzn CFX 18 October 2, 2009 04:18
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Warning 097- AB CD-adapco 6 November 15, 2004 05:41
