-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   Eulerian VOF method-outlet boundary????? (https://www.cfd-online.com/Forums/fluent/120492-eulerian-vof-method-outlet-boundary.html)
sajeesh July 8, 2013 09:35
Hi
I am doing a 2D simulation for the movement of a water droplet having Diameter 25 micrometer through a channel of cross scetion 50 micro X 500 micro..
Using Eulerian VOF coupled method to explicitly define the velocity of droplet and oil phase
I patch the droplet phase and assign a volume fraction of 1 to that water droplet patched region
I am using transient case with double precision
Oil as primary phase and secondary phase as droplet
scheme: phase coupled SIMPLE gradient : Least sqaure method Momentum : first order upwind volume fraction: geo construct
Inlet BC: velocity for oil and droplet volume fraction zero and droplet velocity also at inlet
when i am using Outlet boundary condition
I have to define the back flow volume fraction.
initially If i give the back flow fraction as 0 the simulation running fine and give the correct tracking of interface also
For me i want to eject the droplet from the exit.But by this condition after the simulation the droplet is stuck at exit.solution gets stopped by the high courant number
Similarly i tried with outflow BC.at that time also simulation perfect upto reaching the outlet then again the simulation stopped and the droplet is not going out.
When i tried outlet boundary condition with back flow volume fraction of droplet as 1 it is showing error ->Solution diverging ..velocity diverging .Global courant number more than 250..
Please help me to eject the droplet from the channel during simulation.For that what BC should i give at outlet...
My email ID sajeeshperil@gmail.com
Thanking You
sajeesh
otsigun July 10, 2013 04:34
I am also working on similar Project on wetting Dynamics of an indium droplet. Can you send me your files, so that I can recommend something mehmet.yigit.balta@gmail.com
sajeesh July 10, 2013 08:25
sir what files you want....
case and data file
otsigun July 10, 2013 09:26
yes please send me case and last data file so that i can look through
sajeesh September 23, 2013 01:38
sir
did you get my mail..have seen the files....pls reply me..if you got it
Sajeesh
sajeesh September 23, 2013 01:59
sir
Sajeesh
otsigun September 26, 2013 03:34
droplet
Hi saajesh:
I think you should try like this:
1 Finer mesh
VOF method instead of Euler
Implicit instead of explicit
Servers:
Pressure based Coupled
Least square cell based
Quick
Quick
Small time steps (like 1e-6)
My droplet and tank project with wall adhesion worked like this
Sorry for the late answer, Good luck!
sajeesh September 26, 2013 09:39
Thanks sir for reply
How i can give velocity for the droplet if i select the VOF model
I want to give different velocity for the droplet.
To study the internal external velocity vectors at differnt flow rates of discrete phase
Sajeesh
