July 8, 2013, 09:53 |
negative pressure
Sa.Baraty
Rep Power: 13 |
Hi all.
I simulated one heat sink that has some microchannels. and boundary conditions: 1 velocity inlet for fluid inlet 2 pressure outlet for fluid outlet. and two thermal boundary for heat sink. when converge my RUN pressure @ out let become negative.!???? please help me.
thanks |
July 10, 2013, 03:43 |
Philipp
Rep Power: 26 |
You mean the pressure at the pressure outlet becomes negative?
The skeleton ran out of shampoo in the shower. |
July 10, 2013, 15:28 |
Sa.Baraty
Rep Power: 13 |
yes.pressure @ outlet becomes negative
thanks |
July 11, 2013, 03:03 |
Philipp
Rep Power: 26 |
But this doesn't make any sense to me. If you set the outlet pressure to some value (as a BC), how can this value change during your simulation?
July 11, 2013, 04:19 |
Philipp
Rep Power: 26 |
Yes, but he says "converge" in his initial post. I doubt he will get convergence in such a case.
July 12, 2013, 02:14 |
Sa.Baraty
Rep Power: 13 |
yes my RUN become converge. But pressure value @ outlet is negative.for example pressure @ inlet B.C be 5687 Pa. and @ Outlet B.C be -879 Pa.
thanks |
July 12, 2013, 03:33 |
Alex
Rep Power: 46 |
Please post images of the velocity and pressure contours and of the residuals.
July 12, 2013, 04:37 |
#9 |
Philipp
Rep Power: 26 |
Generally, negative pressures are no problem, since your pressures are gauge pressures. There is a large positive offset of 1e5 Pa to them...
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Raise pressure level in simulation to avoid negative pressures | solimcfd | CFX | 3 | June 13, 2012 07:28 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 06:40 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
