Home > Forums > FLUENT
Understanding Port Flow Results
Old   July 15, 2013, 23:11
Default Understanding Port Flow Results
Reece
Ospi is on a distinguished road
I have been running some port flow analysis using the ICE system within Fluent and I have gathered results from the tests however I do not fully understand what they are telling me.
My setup and results are as follows: Note that is this an exhaust port analysis an so the flow is from cylinder to atmosphere.
Now I'm not sure exactly what I should be looking for as far as correct monitors for the result I want. The goal is to compare various port designs to determine which flows the best. Should I be monitoring the port exit plane (the red line) with a Mass Flow Rate monitor? Will that tell me the mass flow rate that the plane is seeing? I am assuming that the outlet mass flow rate is going to be less accurate due to it measuring a volume after my point of interest but I may be incorrect there as well. In some inlet examples I have seen the area weighted average velocity is monitored but I'm not sure this is what I am after.
Thanks for any advice.
Ospi is offline   Reply With Quote
Thread Tools
Trackbacks are On
starting compressible flow from incompressible flow results mihaipruna OpenFOAM Running, Solving & CFD 2 December 3, 2012 11:02
Flow meter Design CD adapco Group Marketing CD-adapco 3 June 21, 2011 08:33
on curved channel flow numerical results yfyap Main CFD Forum 4 February 8, 2011 05:44
good Cold Flow Results but problem with Hot Flow Rams FLUENT 1 June 18, 2006 19:59
exemple of simulation results in reactive flow GACEM_hatem Phoenics 0 June 6, 2001 14:13
