-   FLUENT (
-   -   How to Set Pressured Outlet Boundary Condition? (
CFDisFUN July 16, 2013 08:45
I am trying to model a portion of a pump-driven flow in a pipe and I am not sure about its BCs. I set the Velocity Inlet for the inlet with a specific fluid velocity. For the outlet, I can choose "Pressure Outlet" BC, but it also ask for a temperature that I am not sure.
Can anyone advise on BCs of pumped flow (so the outlet is not zero pressure)!
Thank You.
Jim87 July 16, 2013 12:09
In my opinion the temperature of the pressure outlet for an continous system isn't that important. The fluid flows out of your system and the heat-transport against your flow direction isn't significant.
In order to avoid bad residuals I usually choose the inlet temperature or the reference temperatur.
Actually I can't remember a tutorial case where the outlet temperature where really important for the results.
CFDisFUN July 16, 2013 12:18
Jim87, Thanks a lot!
