How to Set Pressured Outlet Boundary Condition? |
July 16, 2013, 08:45 |
Mike
Rep Power: 13 |
I am trying to model a portion of a pump-driven flow in a pipe and I am not sure about its BCs. I set the Velocity Inlet for the inlet with a specific fluid velocity. For the outlet, I can choose "Pressure Outlet" BC, but it also ask for a temperature that I am not sure. Can anyone advise on BCs of pumped flow (so the outlet is not zero pressure)! Thank You. |
July 16, 2013, 12:09 |
Stephan Langenberg
Rep Power: 14 |
In my opinion the temperature of the pressure outlet for an continous system isn't that important. The fluid flows out of your system and the heat-transport against your flow direction isn't significant.
In order to avoid bad residuals I usually choose the inlet temperature or the reference temperatur. Actually I can't remember a tutorial case where the outlet temperature where really important for the results. |
July 16, 2013, 12:18 |
Mike
Rep Power: 13 |
Jim87, Thanks a lot!
outlet boundary condition | Nina Schiepel | CFX | 2 | July 12, 2008 15:27 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
Outlet boundary condition | Asghari | Main CFD Forum | 0 | May 5, 2006 16:51 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
outlet boundary condition | neil | CFX | 1 | June 17, 2002 00:57 |
