July 18, 2013, 01:39 |
DPM injection
Rep Power: 14 |
Hi, wonder if anyone encounter this when they set up DPM droplet injection. The DPM particles will have a reverse flow phenomenon (the particles will flow upstream of flow, even though it is injected in a downstream position)
July 18, 2013, 21:08 |
Stuart Buckingham
Rep Power: 25 |
How are you defining the injection? Is there a velocity component that could cause this? Also, what body forces do you have in your model?
Stu |
July 19, 2013, 10:09 |
Rep Power: 14 |
The injection can be pressure swirl or plain orifice. Think of a cylindrical duct with airflow flowing from left to right. There is a wall injection perpendicular to the wall and flow direction. The injected particles will flow to the left before making a u-turn to the right, hence why I described as reverse flow.
Dpm injection mass flow rate | diamondx | FLUENT | 0 | November 22, 2012 13:04 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 11:12 |
Dense DPM Injection Help (basic sedimentation) | sgelman | FLUENT | 0 | July 21, 2010 14:19 |
On DPM injection properties. | akr | FLUENT | 4 | October 23, 2006 10:54 |
DPM, UDF, Injection Type | Zhang | FLUENT | 0 | June 8, 2005 15:51 |
