October 23, 2012, 15:33 |
Plotting injections and fluid
Rep Power: 13 |
I'm working on a 2-D project using FLUENT. I have 2 inlets and multiple outlets. I injected particles at different diameters to see how they flow with the fluid. I can plot the stream function for the fluid and for the injections. Is it possible to plot both of them both on the same plot?
I need to do this because I am trying to see what size particles will follow the streamlines of the fluid(air) and what size particles will fall away from the flow. |
October 23, 2012, 16:43 |
barzin
Rep Power: 15 |
Hey bud,
As far as I know u can't do it using FLUENT but if you've got access to CFD-post, it can do it for u easily! |
October 25, 2012, 15:21 |
Mario Tremblay
Rep Power: 13 |
I think you can do it with Tecplot360.
October 29, 2012, 09:27 |
I like to process the data from fluent with Matlab for data processing is convenient, and I remenber the streamlines data can be saved as tecplot data(file-export-tecplot) directly,then you can read the saved data to Matlab.
October 29, 2012, 15:36 |
Rep Power: 13 |
Ok thanks everyone for your advice.
July 22, 2013, 04:06 |
Dr. Moloy Kumar Banerjee
Rep Power: 14 |
Dear S1m0n1
Could you solve your problem regarding the plotting of stream function for both fluid and particle? if it is so, then please help me in this regard. |
Display Modes | |
Modeling solid particles within fluid flow | steelydan | ANSYS | 1 | July 22, 2011 04:01 |
Injections | Atholl | FLUENT | 3 | August 27, 2002 11:38 |
