Home > Forums > FLUENT
species transport-outflow boundary condition
Old   July 23, 2013, 07:21
Default species transport-outflow boundary condition
Lilly is on a distinguished road
Dear all,
I am simulating a species transport inside a geometry with several outlets and I am using th outflow boundary condition. My question is: does this boundary condition only fix the total flow (like for outflow:0.25-->25% of the total fluid-mixture is passing through this outlet) or is also the amount of species is fixed by the outflow condition (like also exactly 25% of the species is forced to pass this outlet)? I am afraid the latter might lead to wrong results, since depending on the bifurcation the amount of species might be larger or smaller at an outlet...
Does anybody have an idea or a reference?
Thanks a million!
Lilly
Lilly is offline   Reply With Quote
Old   July 28, 2013, 13:00
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hey
Off course, the first one is correct, a portion of total mass flow.
Regard yours
A CFD free user is offline   Reply With Quote
Old   August 2, 2013, 03:24
These are good news! Thanks a million for your reply!
Old   August 30, 2013, 12:22
vix
Vikram M.
vix is on a distinguished road
Dear Lilly,
I am looking to model something similar - contrast agent in blood through a realistic geometry of an artery with a stenosis. I am interesting in seeing the concentration of the agent downstream of the stenosis.
However, I am new to the species transport model.
I have been reading around and so far I understand that I would need an inlet mass fraction for the dye and the diffusion coefficient to use the species transport model. I will assume a zero flux through the wall but I am not sure what outlet bc to use. I only have 1 outlet.
Should I be prescribing a mass fraction at the outlet ( I don't have this information) ? or just use the outflow condition.
Thanks for your input in advance
Vix.
vix is offline   Reply With Quote
Old   September 4, 2013, 04:59
Dear vix,
since I am interested in how the contrast agent bolus shape looks at the outlet I am using the outflow boundary condition and I do not set a bolus shape there. But you could also use a pressure outlet for example. I don't think you have to fix the mass fraction of the species at the outlet there (even though you have the possibility to do so). Do you have information of how your bolus looks there?
Good luck,
Lilly
Old   September 4, 2013, 05:58
vix
Vikram M.
Hi Lilly,
Thanks for your reply.
I do not know how the bolus looks at the outlet so I guess using either an outflow condition or a pressure outlet would be sufficient (without specifying a mass fraction)
I am mainly interested in seeing if there is an increase in the concentration of the species downstream of the stenosis as there is a recirculation zone which occurs there.
Would you be able to help with a few questions I have as I go along this simulation ? I would really appreciate it.
For example, when you select the species transport model, you are supposed to select a mixture. What mixture have you chosen ? or if you have created your own mixture, is it just the contrast agent and the blood. What properties would you need to specify for the two ?
I read somewhere that the agent should be first and the blood should be second since blood is the bulk fluid. Is that correct ?
Thanks for your help
Vix.
Thread Tools
Trackbacks are On
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
Outflow boundary condition for convecction-difussion problem. juanelo14 Main CFD Forum 0 September 27, 2012 00:20
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
outflow boundary condition foe flow over a cylinder Ardalan Main CFD Forum 0 April 29, 2010 13:04
