Grid interface between solids
Old   July 23, 2013, 05:03
Default Grid interface between solids
Agustín Villa
agustinvo is on a distinguished road
Hi everyone!
I'm trying to get a grid interface in this way, where S is an interface from a solid zone, s is an interface from another solid, and F is the interface whichs belong to a fluid zone:
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
FFFFFFFFFFFFFFFFFsssssssssssssFFFFFFFFFFFFFFFF
My probles is the next one: when I create a grid interface between the upper solid and the fluid, I have to link the solids S and s too, but I can't do it because the upper interface has been used, and Fluent crashes.
I thought about create the grid interface using F and s as one interface, and S as the other one. My question is about the coupling between the interfaces: S and F have to be coupled, but s and S will be coupled if I do this in this way? What could it mean two coupled solids?
agustinvo is offline   Reply With Quote
Old   July 23, 2013, 06:01
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Not sure if I completely understood your problem.
If I had a setup like this, I would split the upper face ("SSSSS...") into three parts matching the opposing faces geometrically.
|| denotes a split in my "sketch"
SSSSSSS||SSSSSSS||SSSSSSS
interface1---Interface2---interface3
FFFFFFFF sssssssss FFFFFFFF
flotus1 is offline   Reply With Quote
Old   July 23, 2013, 06:27
Agustín Villa
That's a good idea, but I can't do that: the upper side has another face above it, and all of them twist: if I split the upper GI, I will have problem with the mesh (fixed notes at the upper-upper wall, and totating nodes at the face with interface).
Bu if I try it, I think I could do as you say, spliting the volume, in order to obtain your three interfaces... I'll try to mesh it
Thanks!
coupled, grid interface
Radiation interface hinca CFX 15 January 26, 2014 17:11
[Netgen] creating interface in two solids in Netgen jr33 OpenFOAM Meshing & Mesh Conversion 0 February 11, 2013 19:25
How work with grid interface?? teguhtf FLUENT 12 October 29, 2009 01:56
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
periodic grid interface santosh FLUENT 3 August 30, 2001 10:06
