Home > Forums > FLUENT
How to relate two zones which both are rotating?
Like Tree1Likes
  • 1 Post By vasava
Old   July 23, 2013, 16:37
Default How to relate two zones which both are rotating?
parham007 is on a distinguished road
Hi. I can't finish my project and I keep getting errors. I think its because I don't use the proper model. Assume there are two rotating zones which fluid exits the 1st zone and has to enter the 2nd one (in a pump which the first zone consists the hub and the 2nd zone is between the blades). Its like pressure outlet of the 1st one is the pressure inlet of the 2nd one but I haven't got the values and they may change over time (may be!). Therefore I searched the net and found the following models: Mixing plane and Sliding mesh.
I don't know which model to use or are they the right ones for my problem?
I can't figure it out! Help me out!, please! (I must finish it on time )
parham007 is offline   Reply With Quote
Old   July 24, 2013, 07:48
Paritosh Vasava
vasava will become famous soon enough
You must look at FLuent tutorial about multiple frame of reference. It has clues and probably answers to your questions. All the best!!
parham007 likes this.
vasava is offline   Reply With Quote
Old   July 24, 2013, 10:44
Vasava thank you very much for your reply. Actually I have used the MRF in each zone. Presume one has a pressure outlet which needs to be connected to a pressure inlet right next to it but doesn't know about the values of pressure. The problem is if not via pressure outlet-inlet then how to connect and relate these zones together?
Old   July 24, 2013, 15:00
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Pictures are welcome. They are really helpful to understand the problem...
Far is online now   Reply With Quote
Thread Tools
Trackbacks are On
Problems with rotating machinery (Centrifugal Pump) in FLUENT RR2 FLUENT 1 January 17, 2016 06:23
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
MRFZones with two rotating zones chemeng OpenFOAM 3 March 11, 2010 02:15
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
