Density XY plot of a plane
Old   July 25, 2013, 10:01
Default Density XY plot of a plane
FHydro
flow_CH is on a distinguished road
Hello
I am simulating an open channel flow with air and water.
The densities for air and water are min 1.22 to max 998 kg/m^3
I want XY plot of "890 kg/m^3 density" on a center plane of channel. I am defining the plane in surface--->plane and "890 density" in iso surface panel.
But in XY plot panel, i cannot plot "890 density" on defined plane. The plots for densities are separate for plane and "890 density" The "890 density" is plane itself. I mean, i want 890 density on defined plane.
I hope you understand what I mean.
Thanks
flow_CH is offline   Reply With Quote
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 00:06
[OpenFOAM] How to get density color plot in twoPhaseEulerFoam ploceus ParaView 2 February 19, 2020 13:38
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
