question to the fluid mechanicans
Old   July 29, 2013, 02:55
Default question to the fluid mechanicans
Stephan Langenberg
Jim87 is on a distinguished road
I've problems with the model validation for my fluent simulation. I need an analytical equation for ime dependant pressure reduction...
- The simplified model:
At the beginning a compressible fluid (visco-elastic Polymer) is under high pressure und Temperature in a fixed geometry (think of a block)
Now one of the Faces is removed and the fluid is able to expand into the free room (space behind the removed face).
At the end of the free space is a pressure outlet, so that the material can reduce the pressure to standard atmosphere (1 atm)
My question is: How is the physical description of a time dependant pressure decrease for a fluid material that is compressible or better
(visco-elastic)
- In my opinion viscosity (a kind of inertia) have to influence the compression and decompression process. May I use a modified Bernoulli equation or a special differential equaution for the time dependant pressure drop?
Jim87 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[ICEM] Question about fluid domain dividing lnk ANSYS Meshing & Geometry 0 July 19, 2012 14:19
Question on PISO algorithm in computation fluid dynamics book by Chung Hooman Main CFD Forum 2 June 9, 2012 07:35
Question on heat tranfer from an obstacle into fluid ekh95 FLOW-3D 0 June 3, 2009 18:09
Fluid flow in porous media question Orlando FLUENT 2 September 12, 2001 10:31
