System coupling doesn't detect participants
Old   July 31, 2013, 21:02
Default System coupling doesn't detect participants
AGP
Anonymous
AGP is on a distinguished road
Hi Guys,
I am doing a two-way FSI using system coulping with FLUENT and Static structural. But for some reason, the system coupling setup doesn't detect the participants. I have connected both FLUENT and Static structural setups to it. Is it a licensing issue? Can something be done to fix it?? I would greatly appreciate any inputs..
Sincerely,
AGP
AGP is offline   Reply With Quote
Old   August 2, 2013, 08:39
stumpy is on a distinguished road
What are the errors in the Fluent, System Coupling and Structural output files? It could be licensing. If you are using academic licenses make sure shared licensing is disabled in the license preferences.
stumpy is offline   Reply With Quote
Old   August 6, 2013, 16:01
AGP
Anonymous
There are no errors in FLUENT and static structural. The participants aren't detected in the system coupling section. I have disabled shared licensing. Any other suggestions??
Old   August 7, 2013, 08:58
Could you turn on the debug output in System Coupling to "All Levels" then copy the last section of the System Coupling output here?
Old   August 7, 2013, 13:04
AGP
Anonymous
Thank you so much Stumpy for your response. I have turned on the debug output in System Coupling to "All Levels". But I don't see any output or any error messages. Can you please let me know which section are you exactly talking about.
Old   August 7, 2013, 15:31
There were no Data Transfers defined in that screen shot - see the question marks in the tree. Is that the case you are trying to run?
Old   August 7, 2013, 16:11
AGP
Anonymous
Yes. This is the case I'm running. I can't define data transfers because the participants aren't getting detected.
Old   August 7, 2013, 17:38
Ah, I see. I thought this was when solving. That's strange, never seen that happen. I assume there's an FSI interface in the Static Structural system. Does the oscillating plate tutorial work OK?
Old   August 7, 2013, 17:51
AGP
Anonymous
I forgot to click on update project!!
Old   April 12, 2019, 12:08
Default Thanks!
Viraj Gandhi
Viraj32 is on a distinguished road
Thanks for the solution!
I wouldn't have been able to guess!
Viraj32 is offline   Reply With Quote
Old   March 2, 2020, 01:19
Rupali
Rupali is on a distinguished road
I am also facing a same kind of error (see attached). Please suggest me how to resolve the issue.
https://ibb.co/rf73GQT
Rupali is offline   Reply With Quote
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 09:12
system coupling ansys 14 - error karupps8 Main CFD Forum 1 May 20, 2014 21:36
How can I track the progress of FLUENT when running ANSYS System Coupling yhy20081016 FLUENT 1 June 4, 2013 12:03
2-way FSI, System Coupling error Arty Main CFD Forum 1 May 12, 2013 14:41
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
