call temperature in Profile UDF
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 21, 2021, 00:26
Default call temperature in Profile UDF
sina
sina_sls is on a distinguished road
In DEFINE_PROFILE , I want to call temperature of cell but when i run the file error "Node 0: Process 1404 : Received signal SIGSEGV" comes up .I'm sure problem because of C_T(c,t) .How can i call temperature in DEFINE_PROFILE?
here's my udf:
DEFINE_PROFILE(temperature_profile,t,i)
cell_t c;
float temparc;
float timeflow = CURRENT_TIME;
begin_c_loop(c,t)
if (timeflow>=0.021 || timeflow<=0.0346){
temparc=C_T(c,t);
F_PROFILE(c,t,i) =temparc;
else
F_PROFILE(c,t,i) =600;
end_c_loop(c,t)
Best Regards,
sina_sls is offline   Reply With Quote
Old   November 21, 2021, 22:47
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
instead of float use real
this UDF could work only in zones (not boundaries) apply it correctly.
put #include "udf.h" in the very first line
sina_sls likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 22, 2021, 09:05
sina
Thank you for your response, I used #include "udf.h" but I didn't copy here I forgot.
I have another problem I want to write profile (udf) which for specific time use tabular data and out of these time use the temperature that FLUENT is computed. but when i want to use temperature that FLUENT is computed it gets me the last temperature in tabular data how can I define that don't use these tabular data after specific time here is my part of code
/* Interpolate temperature from look-up table and assign to cell value */
cell_t c;
float time_flow = CURRENT_TIME;
float temparc;
float tempp=C_T(c,t);
begin_c_loop(c,t)
if (time_flow>=0.021 && time_flow<=0.0346){
temparc=get_tem_from_time(time_flow);
}else
F_PROFILE(c,t,i) =tempp;
end_c_loop(c,t)
Old   November 22, 2021, 09:07
sina
cell_t c;
float temparc;
begin_c_loop(c,t)
}else
end_c_loop(c,t)
Old   November 22, 2021, 22:59
Alexander
show code for get_tem_from_time function
best regards
Old   November 24, 2021, 13:53
sina
#include "udf.h"
int NPts_tem = 111; /* number of entries in temperature table */
/* Locate the place in the interpolation vector using bisection algorithm*/
int locate(float xx[], int n, float x)
int j = 0;
int jm = 0;
int jl = 0;
int ju = n+1;
int ascnd = 0;
ascnd = (xx[n] >= xx[1]);
while (ju-jl > 1)
jm = (ju+jl) >> 1;
if (x >= xx[jm] == ascnd)
jl = jm;
else
ju = jm;
if (x == xx[1])
j = 1;
else if (x == xx[n])
j = n-1;
else
j = jl;
return j;
/* -----Understood------ */
float *time_vec_tem,*tem_vec;
#define FAST_LOOKUP TRUE /* use bisection algorithm for interpolation */
#define TABLE_MESSAGES TRUE
#define DISPLAY_TABLES TRUE
/* Obtaine mu given temperature */
float get_tem_from_time(float xdata)
int i = 0;
int j = 0;
float xL,xU,ydata;
#if FAST_LOOKUP
j = locate(time_vec_tem,NPts_tem,xdata);
xL = time_vec_tem[j];
xU = time_vec_tem[j+1];
ydata = tem_vec[j] + (xdata-xL)/(xU-xL)*( tem_vec[j+1] - tem_vec[j] );
#else
for ( i=1; i<NPts_tem ;i++ )
xL = time_vec_tem[i];
xU = time_vec_tem[i+1];
if ( (xdata>=xL)&&(xdata<=xU) )
ydata = tem_vec[i] + (xdata-xL)/(xU-xL)*( tem_vec[i+1] - tem_vec[i] );
break;
#endif
if ( xdata>time_vec_tem[NPts_tem] )
#if TABLE_MESSAGES
Message("n temperature is above the bound of visc-array n");
#endif
ydata = tem_vec[NPts_tem];
if ( xdata<time_vec_tem[1] )
#if TABLE_MESSAGES
Message("n temperature is below the bound of visc-array n");
#endif
ydata = tem_vec[1];
return ydata;
/* -----Understood------*/
/* Read in the data file containing temperature as a function of time */
DEFINE_ON_DEMAND(read_arctemperature)
int i = 0;
float xdata,ydata;
FILE* fp;
fp = fopen("arctemperature.dat","r");
if ( fp!=NULL )
#if !RP_NODE
Message(" \n");
Message("Reading file arctemperature.dat \n");
Message(" \n");
#endif
else
#if !RP_NODE
Message(" \n");
Message("Error opening file \n");
Message(" \n");
#endif
time_vec_tem = (float *) malloc(NPts_tem*sizeof(float)); /*Dynamic Memory Allocation*/
tem_vec = (float *) malloc(NPts_tem*sizeof(float)); /*Dynamic Memory Allocation*/
if ( (time_vec_tem==NULL)||(tem_vec==NULL) )
#if !RP_NODE
Message("Memory allocation error \n");
#endif
for ( i=1;i<=NPts_tem;i++ )
fscanf(fp,"%e %e \n",&xdata,&ydata);
time_vec_tem[i] = xdata;
tem_vec[i] = ydata;
#if DISPLAY_TABLES
#if !RP_NODE
Message("%e %e \n",time_vec_tem[i],tem_vec[i]);
#endif
#else
#if !RP_NODE
Message(" \n");
#endif
#endif
fclose(fp);
cell_t c;
float temparc;
begin_c_loop(c,t)
}else
end_c_loop(c,t)
profile, udf
Temperature Profile UDF AC1993 Fluent UDF and Scheme Programming 1 November 1, 2016 02:15
Temperature profile UDF for 3D cylinder surface Himel Fluent UDF and Scheme Programming 1 June 16, 2015 10:59
defining temperature profile with UDF mohammadkm Fluent UDF and Scheme Programming 11 July 3, 2013 00:15
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
UDF for linear temperature profile on horizontal parallel surfaces. Chirag2302 Fluent UDF and Scheme Programming 0 February 4, 2012 00:44
