Home > Forums > FLUENT
Recommend some boundary conditions for a DES
Old   August 1, 2013, 04:06
Default Recommend some boundary conditions for a DES
siw
Stuart
siw will become famous soon enough
For a DES of a flat plate in a domain similar to that in:
http://turbmodels.larc.nasa.gov/flatplate_val.html
but in my case there's also an obstacle on the plate. Also my domain size is larger and in 3D, but periodic BC sorts out the spanwise sides.
What would be the recommended DES boundary conditions where the image in the hyperlink shows symmetry and farfield Riemann BC?
Symmetry should not be used in any DES (or LES) so will Fluent allow an outlet here so that any flow fluctuation can either exit or enter without any reflection or other constraint? Also can the same be used for the fafield Riemann BC? In my case the flow is incompressible so the Fluent pressure-farfield is not suitable as that is for compressible flow.
Thanks.
siw is offline   Reply With Quote
Thread Tools
Trackbacks are On
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
boundary conditions and mesh exporting vaina74 Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 May 27, 2010 09:38
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
