Fluent FSI time step restart?
Old   August 2, 2013, 08:25
Default Fluent FSI time step restart?
Samer
SamerAli is on a distinguished road
Dear All
let's say i launched a simulation and i stopped it at t=10 seconds, and i want to restart the simulation for example not from 0 but from t=5 seconds, is there a way to do this in FSI ansys fluent?
SamerAli is offline   Reply With Quote
Old   August 2, 2013, 08:37
stumpy is on a distinguished road
Using System Coupling? If you set Intermediate Restart Data Output in System Coupling then yes, otherwise no.
stumpy is offline   Reply With Quote
Old   August 2, 2013, 09:33
Samer
yes using system coupling, i use intermediate restart data output, but when i restart from a previous time step, it says an error that Fluent input time is different from system coupling
Old   August 2, 2013, 17:15
There's a workflow in the documentation to follow if you are not just continuing. You'll need to open the Fluent Solution cell then use File > Solution Files to pick the correct time point. In Mechanical and System Coupling you'll also need to manually pick the correct restart points. If everybody is using the same time point it should restart.
FLUENT: how to record drag force at every time step? qiulan FLUENT 4 March 20, 2017 21:22
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
