Euler-based parallel Newton- K r ylov-Schur ow solver
Like Tree1Likes
  • 1 Post By cdegroot
Old   July 12, 2013, 21:12
Thumbs down Euler-based parallel Newton- K r ylov-Schur ow solver
pranali
pranali is on a distinguished road
I am final year student and taken up project of cfd analysis of blended body wing aircraft. I have found AIAA journal on this and they are using "Euler-based parallel Newton- Krylov-Schur ow solver" to solve the flow at M=.85 Now I want to know if there is equivalent model in fluent to solve the flow??
pranali is offline   Reply With Quote
Old   July 14, 2013, 23:19
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Just use the inviscid solver (i.e. to solve the Euler equations). Newton-Krylov-Schur just refers to how the system of equations is linearized and solved, which isn't really important if you are just looking for a solution. Fluent uses an algebraic multigrid method to solve its linear systems, not a Krylov method. Not sure if a Krylov option exists somewhere, but it is not the default.
pranali likes this.
cdegroot is offline   Reply With Quote
Old   August 3, 2013, 06:39
pranali
thanks for your suggestion
LTS based Lagrangian particle solver and test cases ulli OpenFOAM Announcements from Other Sources 17 April 13, 2021 08:06
Boundary face values in density based solver? Chen Zhi FLUENT 3 November 28, 2019 06:51
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 15:59
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 21:08
How to compile an unsteady solver based on solver of MRFSimpleFoam? renyun0511 OpenFOAM Running, Solving & CFD 0 April 27, 2010 11:16
