Surface cutting geometry in several planes
Old   August 8, 2013, 11:07
Default Surface cutting geometry in several planes
Prateek Anand
Thermal_engg is on a distinguished road
Hello everyone,
I am modelling a rectangular natural circulation loop with isothermal heat source and heat sink and the rest of the surfaces adiabatic.
I am using carbon dioxide as a fluid and employing NIST real gas model in the supercritical region of CO2.
I wanted to calculate bulk mean temperature at a cross section of the isothermal heat source .For that I created a plane surface in FLUENT.It is creating a cross section in the heated section but it is also creating a cross section in the cooled section(since the geometry is rectangular and Fluent just asks the 3 points on the plane,not the bounds of the plane)
As a result my geometry is cut into 2 places ,wherever the plane intersects it
Can any1 tell me how to create a bounded plane in one of the sections only? Thnx
Thermal_engg is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] Solution Snappy Hex 2D Msh with Surface Layers and cyclic bc for symmetric geometry flexi182 OpenFOAM Meshing & Mesh Conversion 0 May 24, 2013 08:38
plane cutting complex geometry in the middle Lilly FLUENT 0 July 27, 2011 09:01
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
