Fluent diverges when using inflation layers
Old   August 9, 2013, 09:51
Question Fluent diverges when using inflation layers
Bart A.
ziggo is on a distinguished road
I'm simulating a 2D wedge in a flow with the transient standard k-epsilon model. The Reynolds number is around 400000.
The geometry is shown below.
The mesh without inflation layers gives a solution with a CD of around 1.2. This is close to literature values of a 2D wedge in a flow.
However, when I add the inflation layers (and change nothing else in the mesh), the solution diverges after one timestep and I get a warning that the turbulent viscosity is limited to a viscosity ratio of 1e5 in several thousand cells.
In the end Fluent stops iterating with the message:
Divergence detected in AMG solver:y-momentum
The first inflation layer thickness is set such that y+ is around 30. Setting it such that y+ is 1 did not solve the divergence.
I've read up on the viscosity ratio warning in different posts here and in other internet resources, but the remedies (refining the mesh, under-relaxing the k and e) did not work for me.
I'm surprised that adding an inflation layer has such a big (negative) effect on my solution. Can someone explain what is happening here?
Should I just leave the inflation layers out all together (sounds like a bad idea)?
1. Geometry overview, flow comes from the left, normal to the boundary:
2. Geometry close-up:
The mesh without inflation layers looks as follows:
3. Mesh overview:
4. Mesh refined area:
5. Mesh around wedge:
And with inflation layers:
6. Mesh around wedge with inflation layers:
7. Mesh around wedge nose with inflation layers:
ziggo is offline   Reply With Quote
Old   August 9, 2013, 10:10
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Have a look at the cells at the sharp trailing edges of your geometry.
I guess they have very small angles.
flotus1 is offline   Reply With Quote
Old   August 9, 2013, 10:23
Bart A.
The trailing edge looks like this:
How do I prevent too sharp angles in the mesh?
Old   August 9, 2013, 10:28
flotus1's Avatar
Alex
An easy way could be to refine the mesh in this region (which you should do anyway because the mesh is rather coarse here).
Old   August 9, 2013, 12:11
Smile
Bart A.
I've refined the mesh at the trailing edge by adding an edge sizing restriction on the edges of the wedge. It now looks like this:
Fluent does converge now. Thank you for your help.
divergence, fluent 14, inflation layer
Connecting Fluent benefits and Injection Molding Software Jim87 FLUENT 1 August 6, 2023 16:06
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Results are different for Ansys Fluent 14.0 and Fluent 6.3 syavash Fluent UDF and Scheme Programming 1 February 17, 2013 01:09
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
