Home > Forums > FLUENT
how to plot mach number along a curve in 3d?
Like Tree1Likes
  • 1 Post By gholamghar
Old   August 18, 2013, 16:05
Default how to plot mach number along a curve in 3d?
gholamghar is on a distinguished road
Hello all,
I have a question about postprocessing:
I have a 3d gas turbine blade, I need to create a line parallel to pressure side or suction side with 1mm distance from them, and then report the Mach number along that line. Do you have any ideas how i can do this in 3d?
in 2d, I just go "Surface-Transform" and then create a line 1mm away by using "Iso-distance", but in 3d when I use the same option instead of creating a line it creates a plane, and I just need a line. Can anyone please tell me how should I create that line in order to report the Mach number along it?
Thanks a lot
gholamghar is offline   Reply With Quote
Old   August 19, 2013, 10:43
I found a way myself, but I'm not sure how accurate is the curve. What I did was to go to "surface-> iso-surface", then "surface of constant" mesh, then "z-coordinate", then enter the value in "iso-values" box. then with this new created plane, i go to "iso-clip" and "mesh" and then "cell wall distance", in the min and max boxes I set the value pretty much close to each other for example min=1.00000 and max=1.00001, so that the created plane here would be like a line!
I hope this helps other people having the same problem as me...
zhixin likes this.
Thread Tools
Trackbacks are On
Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Mesh Utilities 41 January 17, 2013 03:43
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Strong oscillation at transonic mach number martingariepy FLUENT 2 May 12, 2009 11:40
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
