-   FLUENT (
-   -   Plotting non-constant surface tension (
akidess August 21, 2013 03:56
I'm setting up a multiphase VoF Fluent case with temperature-dependent surface tension. Little surprising my first attempt has not been entirely successful, so I'd like to check if I'm getting the correct surface tension values. However, I can't find an option to plot the surface tension values in the domain (neither in fluent directly, nor via calculation activities -> export). Can anyone help me out here?
vig August 30, 2013 07:36
You could write a udf for defining surface tension property.
Store the value in the udm and then post-process it.
akidess September 2, 2013 04:57
Ok, thanks!
