Home > Forums > FLUENT
Fluent Line Command
Old   August 30, 2013, 21:30
Default Fluent Line Command
shashank vummidi
shashankvu is on a distinguished road
I am trying to set up boundary conditions via the command line (want to replicate the conditions shown in the jpeg file attachment) ....
define/boundary-conditions/velocity-inlet inlet_2 no no no no
I am trying to change the progress variable in the command line, but I am getting the following error,
define/boundary-conditions/velocity-inlet (inlet_1 inlet_2)
inlet_2 no no no You must select one of the Velocity Specification Method options.
no
Velocity Specification Method: Components [no] it Please answer y[es] or n[o].
Please answer y[es] or n[o].d: Components [no] file/stop-journal
Velocity Specification Method: Components [no] /exit Please answer y[es] or n[o].
yes
Reference Frame: Absolute [yes] Use Profile for Supersonic/Initial Gauge Pressure? [no] Supersonic/Initial Gauge Pressure (pascal) [0] Use Profile for Axial-Velocity? [no] Axial-Velocity (m/s) [0] Use Profile for Radial-Velocity? [no] Radial-Velocity (m/s) [0] Turbulent Specification Method: K and Omega [yes] Use Profile for Turbulent Kinetic Energy? [no] Turbulent Kinetic Energy (m2/s2) [1] Use Profile for Specific Dissipation Rate? [no] Specific Dissipation Rate (1/s) [1] Use Profile for Progress Variable? [no] Progress Variable [0] Use Profile for Progress Variable Variance? [no] Progress Variable Variance [0] Use Profile for Mean Mixture Fraction? [no] Mean Mixture Fraction [1] Use Profile for Mixture Fraction Variance? [no] Mixture Fraction Variance [0]
> Halting due to end of file on input.
I would appreciate any help in trying to describe the velocity inlet via the command line
shashankvu is offline   Reply With Quote
Thread Tools
Trackbacks are On
erros in Allwmake jiwon OpenFOAM Installation 7 December 30, 2015 13:34
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Options when running Fluent from the command line An Modh Coinniolach FLUENT 2 January 14, 2003 05:11
