opening parallel cas and dat files
Like Tree1Likes
  • 1 Post By macchio
Old   August 22, 2011, 14:34
Default opening parallel cas and dat files
darp is on a distinguished road
Hello all,
I've got a bother with Fluent 12.0: I set up my transient case in parallel on 4 processors, run some time steps and then complate the run on an 8 node cluster.
When I try to open the last cas and dat I get an error message
"%non-conformal-mesh?: invalid grid
(..\src\mpsystem.c@1148): mpt_read: failed: errno = 10054
: mpt_read: error: read failed trying to read 8 bytes: No error"
Reading the last TS dat on my initial cas gives me (although nothing has been changed):
Warning: case and data files are inconsistent; zone 27, case [1747482,1776023], data [1747182,1775723]
Trying to open them in serial does not help either.
What am I doing wrong? Has anyone come across these errors before? Any suggestions?
Thanks
Darp
darp is offline   Reply With Quote
Old   August 23, 2011, 04:48
D.Q.Zheng is on a distinguished road
Was your previous cas&dat file saved correctly? If not, such errors might happen.
D.Q.Zheng is offline   Reply With Quote
Old   September 1, 2013, 11:13
macchio is on a distinguished road
The solution for this problem is in this thread:
http://www.cfd-online.com/Forums/flu...computing.html
For all of you who encounter it in the future like I did...
PJTsai likes this.
macchio is offline   Reply With Quote
adapted cas file for pre-adapted dat file jrg FLUENT 3 September 24, 2007 09:43
Hidden info in cas and dat files Dan FLUENT 0 June 7, 2006 08:40
Pb with writing the Case and Dat files Sam FLUENT 2 May 14, 2004 12:16
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
Source code to read Fluent UNS cas and dat files Boyd Pukalo FLUENT 0 November 26, 1999 22:19
