How to set the gradient of scalar when using UDS |
September 2, 2013, 09:39 |
Y Zhao
Hi everyone, I met a problem about adding UDS in Fluent. I would like to see the scalar transportation in a chamber. If I want to set the gradient of scalar at the outlet to be zero which means the scalar there has no change, how can I set it? The inlet and outlet boundary conditions are separately velocity inlet and pressure outlet. Thank you.
All the best, Yuchun |
September 5, 2013, 02:02 |
A-A Azarafza
Hi dude
Just go to the interest B.C, then click on UDS tab and finally select flux (gradient) scalar option from the left side and set zero value for the corresponding parameter. It's easy and straightforward. Good luck
Regard yours |
September 5, 2013, 03:31 |
#3 | |
Y Zhao
I still have a question: in the user's guide, it says "If you select Specified Flux, your input will be the value of the flux at the boundary". Here, is the flux the same as the gradient? |
September 5, 2013, 18:01 |
A-A Azarafza
Hi
Definitely yup. It is actually Neumann boundary condition.
Regard yours |
April 26, 2018, 19:25 |
#5 | |
I have a question about the zero flux condition. When we consider the equation of UDS flux, diffusive flux should be equal to the advective flux a due to the zero flux condition. UC=Dxgradient(C). You were saying it should be zero gradients. It is confusing to me. Can you explain, please? Thanks |
uds gradient of scalar |
Perfect sink for an UDS scalar concentration | Peter023 | FLUENT | 8 | June 28, 2018 11:48 |
How to compute the gradient of a scalar as a post-processing | ayoros | OpenFOAM Post-Processing | 16 | March 21, 2018 06:02 |
A question about UDS (user difined scalar) | chaozhong.qin | FLUENT | 2 | September 22, 2010 05:21 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
How to add the second gradient of UDS | zhou | FLUENT | 1 | September 4, 2003 05:32 |
