Home > Forums > FLUENT
Aeroacoustic runs in Fluent
Old   September 12, 2013, 22:10
Default Aeroacoustic runs in Fluent
Miraj
desaim is on a distinguished road
Users,
I have read through many posts here on the forum and love this place. I am working on my thesis at Embry-Riddle and have come into a little issue. I am supposed to validate experimental results of a NASA technical memorandum. I was given some generic shapes of launch vehicles and am supposed to study the steady and fluctuating pressure of each body.
Currently I am in the process of running some 2D-axisymmetric cases and from there will be setting up a 3D quarter model case. Once I verify that the flow-field is correct and my steady cases are good, I will switch over and start meshing for DES. I have a few questions that could use clearing up.
1.) I noticed that when meshing the boundary layer, there seems to be high aspect ratio cells due to my delta s. I am trying to keep my y-plus around 25-30 for my RANS cases. Normally I understand that aspect ratio should be kept below 10, but from my reading, having a high aspect ratio cell in the flow direction seems to be normal. I also hear running double precision can clear this up. My high aspect ratio cells can be as large as 2,000
2.) I understand that DES is going to take some computational power and so I heard that Scaled Adaptive Simulations(SAS) in fluent may be a good alternative. Can anyone verify this?
3.) Most of my cases are transonic starting out at a M=0.788. I understand that this is a compressible flow and I have a choice between pressure based or density based. I have divergence issues when using a pressure based solver with a coupled scheme. I am not sure if I can just use a density based solver without any preconditioning. This is a little hazy for me. Maybe I can run a transient case with a large time step to initialize the flow?
BTW all meshing is done in pointwise. Thank you in advance for your help and I plan on sticking around the forums and helping many other people!
desaim is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 26 June 9, 2015 15:38
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 5 September 25, 2013 04:40
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
