Home > Forums > FLUENT
low value of y plus at the walls standard k-e model
Old   September 13, 2013, 06:53
Default low value of y plus at the walls standard k-e model
Mfm
meshoxx is on a distinguished road
I have been trying to solve staggered heat exchanger using fluent .I got resonable results but the value of y plus is very low. I dont know is it normal or no way the results are good as long as yplus doesnt fit into the range
Attached y plus plots
meshoxx is offline   Reply With Quote
Old   September 13, 2013, 07:09
Mfm
I attached two plots
1-y plus of one cylinder
2-y plus of one of the walls
thank you
Old   September 13, 2013, 09:14
François Grégoire
macfly is on a distinguished road
You didn't give enough details, it's impossible for anybody to answer your question.
- where exactly are the 'cylinder' and 'wall' boundaries, you should provide a picture
- which wall treatment did you use?
macfly is offline   Reply With Quote
Old   September 13, 2013, 13:45
Mfm
ok I will give complete explanation of the problem .The problem is an example in incropera book (Heat transfer).the mesh file is attached here and also the case file is uploaded here at 4shared
http://www.4shared.com/zip/hBKd1pCd/...t_exchang.html
I hope you can help on that === >Thank you in advance
Old   September 13, 2013, 13:46
Mfm
http://www.4shared.com/zip/hBKd1pCd/incropera_example_heat_exchang.html
Old   September 13, 2013, 13:49
François Grégoire
I will not sign up on 4shared to get your file. Learn how to create public download links with dropbox.
Old   September 13, 2013, 15:05
Mfm
I am familliar with dropbox .
Everything is here ( case, dat and mesh )
https://www.dropbox.com/sh/ocx5n08i5eof1mg/cQDsFtYSCf
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[OpenFOAM-2.1.0] kklOmega RAS Turbulence Model (low Re) alquimista OpenFOAM Running, Solving & CFD 63 September 11, 2014 13:27
Standard Drag Model does not exist for sprayFoam arash1 OpenFOAM Running, Solving & CFD 0 April 8, 2012 17:52
model constants in standard k-epsilon model Yogini Main CFD Forum 0 January 14, 2010 11:33
Standard k-eps model for airfoils Victor Serov Main CFD Forum 3 January 18, 2000 04:25
