September 14, 2013, 11:26 |
2d les
PSM
Rep Power: 12 |
I am using the command (rpsetvar 'les-2d? #t) in fluent
the following message comes in dialog box Error: rp-var-value-set!: undefined variable Error Object: 2d-les? can anybody help. does my system should have visual studio then only it will work Regards |
September 15, 2013, 14:22 |
found the mistake
PSM
Rep Power: 12 |
1. open a 2D case file
note: check Define/Models/Viscous to verify that LES is not present for a 2D problem 2. type (rpsetvar 'les-2d? #t) and press enter note: you have to include the parentheses 3. go to: Define/Models/Viscous and you'll see that the LES model has been enabled for the 2D case. turbulence is a 3D phenomenon and so, by using it to model a 2D problem your results may lose some of their predictive capabilities. |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 22:16 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
