September 16, 2013, 09:00 |
Numerical Issues with Mesh Growth rate?
Adhikar Hariram
Rep Power: 13 |
Hi all
I would like to know if users of Fluent know of any issues that can be incurred in general single-phase CFD flow problems when a polyhedral mesh is used that has a rather rapid growth. The growth of cells increases by an order of magnitude in size from the area of interest to the downstream region of concern and I would like to know if possible overproduction of turbulence could occur due some numerical issue underlying in the code or of any other issues that are associated with rapid cell growth rates. Thanks in advance. (as a side note I am currently using the RNG k-epsilon turbulence model) Regards |
mesh, rapid growth, turbulence, viscosity |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
