time step size too small and max. time steps is not enough
Like Tree1Likes
  • 1 Post By flotus1
Old   September 16, 2013, 11:31
Default time step size too small and max. time steps is not enough
Rexxar
czhao86 is on a distinguished road
I am doing a steady state DPM, and the time step is always in the order of 1e-7s with Brownian force on, and it takes a lot of time steps for them to reach the outlet. I changed the 'Step Length Factor' from 5 to 1, and the time steps I assume only change by 5 times, and it is still too small. Anyone have some idea? Thanks.
Best,
Rexxar
czhao86 is offline   Reply With Quote
Old   September 16, 2013, 12:19
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Its the Brownian forces again...
I assume you have rather small particles.
The usual integration mechanisms when Brownian forces are involved only work (because of stability AND accuracy constraints) if the time step size is in the order of or smaller than the particle relaxation time.
For small particle Reynolds numbers (c_d = 24/Re) the particle relaxation time is
\tau_p= \frac{d^2 \rho_p}{18 \eta_f}.
Here d is the particle diameter, \rho_p is the particle density and \eta_f is the dynamic viscosity of the fluid.
This relaxation time becomes small for small particles, leading to small time step sizes.
czhao86 likes this.
flotus1 is offline   Reply With Quote
Old   September 16, 2013, 12:23
Rexxar
So in another word, if the Brownian motion is on, I can not simulate several hundreds of seconds process, as the time step is 1e9...
Best,
Rexxar
Old   September 16, 2013, 12:27
flotus1's Avatar
Alex
You could do this with implicit integration methods, but this will lead to huge errors in the particle velocity distribution.
I dont know if this is possible in Fluent.
Old   September 16, 2013, 13:27
Rexxar
Thank you very much. Time for me to learn implicit theme then...
Best,
Rexxar
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
