time step size too small and max. time steps is not enough |
September 16, 2013, 11:31 |
Rexxar
Rep Power: 13 |
I am doing a steady state DPM, and the time step is always in the order of 1e-7s with Brownian force on, and it takes a lot of time steps for them to reach the outlet. I changed the 'Step Length Factor' from 5 to 1, and the time steps I assume only change by 5 times, and it is still too small. Anyone have some idea? Thanks.
Best, Rexxar |
September 16, 2013, 12:19 |
Alex
Rep Power: 46 |
Its the Brownian forces again...
I assume you have rather small particles. The usual integration mechanisms when Brownian forces are involved only work (because of stability AND accuracy constraints) if the time step size is in the order of or smaller than the particle relaxation time. For small particle Reynolds numbers () the particle relaxation time is . Here is the particle diameter, is the particle density and is the dynamic viscosity of the fluid. This relaxation time becomes small for small particles, leading to small time step sizes. |
September 16, 2013, 12:23 |
Rexxar
Rep Power: 13 |
So in another word, if the Brownian motion is on, I can not simulate several hundreds of seconds process, as the time step is 1e9...
Best, Rexxar |
September 16, 2013, 12:27 |
Alex
Rep Power: 46 |
You could do this with implicit integration methods, but this will lead to huge errors in the particle velocity distribution.
I dont know if this is possible in Fluent. |
September 16, 2013, 13:27 |
Rexxar
Rep Power: 13 |
Thank you very much. Time for me to learn implicit theme then...
Best, Rexxar |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
directMapped problem | panda60 | OpenFOAM Bugs | 4 | July 8, 2010 10:23 |
