March 6, 2012, 23:25 |
simulation of bottle emptying process
cfd
Rep Power: 15 |
hi
A viscous fluid is present in the bottle.when the bottle is inverted, due to the action of the gravity the the fluid should go out.I want to know the time required to empty the bottle. Plz guide me the approach and boundary condition for this project |
March 7, 2012, 04:00 |
shoeb khan
Rep Power: 14 |
Just use gravity and some liquid in the bottle
make the bottle inverted time should be around 1-2 sec in which bottle will get empty |
March 8, 2012, 01:34 |
cfd
Rep Power: 15 |
hi
Thank u...i completed the simulation..can i plot the counters of pressure and velocity of air and fluid individually? |
March 8, 2012, 03:14 |
shoeb khan
Rep Power: 14 |
Yes definetely you can do that
but how do you know that your simulatuion is converged . |
March 8, 2012, 05:01 |
cfd
Rep Power: 15 |
Hi
The solution will not converge because continuity equation will not balance i am running the solution till all the liquid is completely out of the bottle...It took around 1.5s to empty the bottle... |
March 8, 2012, 05:46 |
shoeb khan
Rep Power: 14 |
let the solution converge then you can see the velocity and pressure and phase countours after the siumulation is converged
September 18, 2013, 08:23 |
Claus Meister
Rep Power: 17 |
http://www.sciencedirect.com/science...6087741100536X
Journal of Food Engineering Volume 109, Issue 3, April 2012, Pages 609–618 3D CFD simulation of bottle emptying processes |
Help, Simulation of Sublimation Process using Naphthalene | buzuzu | FLUENT | 0 | December 26, 2010 16:51 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
Enquiry about the flame simulation in rotary kiln | hassanelattar | FLUENT | 0 | March 25, 2009 07:41 |
Help for simulation of De-sublimation process | sohail | FLUENT | 0 | March 27, 2008 01:51 |
Casting Process Simulation | Anil Shenoy | Main CFD Forum | 1 | February 22, 1999 11:56 |
